Inject Job (Job repository)
LasseThid
Post by LasseThid »
On a Mac you could just point to /Volumes/whatever/everever/, but on Windows if you choose a folder on a mapped network drive the flow doesn't start, so I'm trying to use single line with variables defined using //192.168.1.11/whatever/wherever, but Switch fails to inject the files because file or folder does not exist.
How do I get Switch to find the files on a network server?
Re: Inject Job (Job repository)
In a Explorer window you can copy the path to that folder, paste it then in to Switch and add your variables.
LasseThid
Post by LasseThid »
Still doesn't work Jan...
Now I get the path as \\192.168.1.11\whatever\wherever, but I still get the same error...
Update: It turns out that the flow works correctly if the dumbass who build it enters the correct ip-address for the server... :lol: :lol: :lol:
The correct ip-address in this case is 192.168.135.11... not 1.11...
:lol: :lol: :lol: :lol: :lol: :lol:
