Paused HTTP GET (error)
mart3223
Post by mart3223 »
Hi All,
We recieve in a XML file the location of the printfiles. Sometimes the link is broken, and is it impossible to download the file. But when that happens the HTTP Request gets a red gear, and every other file is put on hold until I manual delete the XML file with the broken link.
Is there a way to put the jobs with a HTTP GET error in the problems folder?
Hope someone can help. Have a nice day!
Kind Regards,
Martijn
Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
Re: Paused HTTP GET (error)
When the server returns a 4xx HTTP status code (400 or higher means an error), the job is sent along the error connection and you can build a clean flow. The most logical status code is 404: URL not found.
The description you give suggests that it returns a 5xx error (these errors mean that there is a problem with the server itself and then Switch puts the element in an error state). In other words, it looks like it is a bad implementation on the part of the server.
Side note: HTTP return values can be tricky. I know of servers implementations that return 200 in such a case. 200 means that it is OK, but they include a message in the return body that there is an error.
billy.olvestad
Post by billy.olvestad »
mart3223 wrote: Wed May 08, 2019 1:18 pm Hi All,
Kind Regards,
Martijn
Are you sure the link is broken? Have you retried the job?
I get this problem a lot with some web servers, and I have just set switch to automatically "retry failed external processes" after 10 minutes in the preferences, and the problems have gone away.
In other words, in my case the links are not broken. It's just that the web server I am connecting to seems to be a bit flaky.
mart3223
Post by mart3223 »
Yes, i'm sure. There are some customers who have a fault in there system. The link in the XML file is then: "http://test.test.com/a.pdf http://test.test.com/a.pdf" 2 links in one string. So it never connects to a webserver (due the faulty link) so we never get a 404 error. I tried to search to a string like ".pdf https" and ".pdf%20https" (URI) if that exist to put the file to the error folder but that doesn't work also.
borisCM
Post by borisCM »
if you use a command line tool like wget you won't get that issue.
it just gives no output.
https://www.gnu.org/software/wget/manual/wget.html
kind regards
mart3223
Post by mart3223 »
borisCM wrote: Fri May 31, 2019 1:04 pm if you use a command line tool like wget you won't get that issue.
kind regards
Thanks, but I think that would be the problem. He is expecting a output but he doesn't get one. I didn't find a solution yet, anyone?
borisCM
Post by borisCM »
could you share a bad url? so i can do some tests?
kind regards
Boris
