Adding an attachment to a PDF
Posted: Tue Jun 18, 2019 5:09 pm
by aandi
Is there a way, in a flow, to add an attachment to a PDF (as would be shown in Acrobat by View > Show/Hide > Navigation panes > Attachments)? Or some other way to store a file into a PDF for downstream processing (for example a large embedded metadata object)?
Re: Adding an attachment to a PDF
Posted: Tue Jun 18, 2019 5:56 pm
by jan_suhr
PDF Toolkit can add attachments to PDF files. you can run it with Execute command and als use Execute Command Friend app to configure the settings.
https://www.pdflabs.com/docs/pdftk-man- ... -op-attach
