XPath in XML with NameSpace
NEOSA
Post by NEOSA »
Hi All,
I'm trying to find the right XPath value of a XML file (aatched to this topic). XML is from Quite Impose Plus.
I need to retrieve a couple of values, and at lesat "Height " "Width"
The following Xpath :
//@N
give me the full list of items available, but I dind't find the right XPath to get the value of "Width"
I would prefer using the good XPath expression, instead of this (for the "Width" case) :
/ns1:QUITEXML[1]/ns1:ITEMS[1]/ns1:DICT[1]/ns1:ITEMS[1]/ns1:DICT[2]/ns1:ITEMS[1]/ns1:DICT[1]/ns1:ITEMS[1]/ns1:F[2]
May some of you could help ?
Thanks a lot for all.
Quite XML file : https://my.pcloud.com/publink/show?code ... lUMJO539pk
Re: XPath in XML with NameSpace
Is this the information you are trying to retrieve?
It seems a bit odd since it is not a number, but "myWIDTH" which you get.
This is the Switch variable:
[Metadata.Text:Path="/dn:QUITEXML/dn:ITEMS/dn:DICT/dn:ITEMS/dn:DICT/dn:ITEMS/dn:DICT/dn:ITEMS/dn:F[@N='Width']",Dataset="Xml",Model="XML"]
Screen Shot 2019-06-26 at 14.42.55.png (254.2 KiB) Viewed 12634 times
mkayyyy
Post by mkayyyy »
To get the Width attribute this XPath expression would work:
//*[@N = 'Width']
NEOSA
Post by NEOSA »
Hi Padawan,
Thanks for your reply :-)
"myWIDTH" was just an example ;-) Real values are number (in pts);
By checking your expression, I found it can be replaced by a shorter version :
//dn:F[@N='Width']
Thanks for helping !
NEOSA
Post by NEOSA »
mkayyyy wrote: Wed Jun 26, 2019 2:53 pm To get the Width attribute this XPath expression would work:
//*[@N = 'Width']
You rock, you replied while I was writing my reply ;-)
Thanks a lot for help.
mkayyyy
Post by mkayyyy »
NEOSA wrote: Wed Jun 26, 2019 3:13 pm
//*[@N = 'Width']
Haha :lol: no problem!
