Java "Includes" Not Working
rgpepper
Post by rgpepper »
What am I missing? I'm attempting to stash a piece of text in the JobState to be retrieved later by a configurator.
var jobName = job.getNameProper();
job.log(1, jobName);
if (jobName.includes ("PORTFL")) {
job.setJobState("PORTFL");
if (jobName.includes ("PORTFD")) {
job.setJobState("PORTFD");
if (jobName.includes ("LANDFL")) {
job.setJobState("LANDFL");
if (jobName.includes ("LANDFD")) {
job.setJobState("LANDFD");
job.sendToSingle( job.getPath());
I get an error at whatever line number the second "if" is on, so presumably my first if statement is incorrect, though I don't get any syntax errors when saving the script
Re: Java "Includes" Not Working
Post by gabrielp »
Take my comments with a grain of salt because I don't have access to Switch Scripter any longer.
1) You have an extra space before you invoke the .includes method
should be
if (jobName.includes("PORTFL")) {
2) MDN says that String.prototype.includes() was introduced for ECMAScript 2015. Last I heard SwitchScriper uses a modified ES4, so this may not be available https://developer.mozilla.org/en-US/doc ... g/includes
You can see what is available in the Scripter string here https://www.enfocus.com/manuals/Develop ... tring.html
3) I think the way to do this in Switch would be to use indexOf on a particular pattern or substring like so:
    if (jobName.indexOf("PORTFL") !== -1) {
    /* etc */
4) I would use a private data key for storing this instead of jobstate because it provides more context about what is stored there and its less likely to get overwritten by something else (including a folder with JS set).
rgpepper
Post by rgpepper »
Thanks! Turns out I did have to use "IndexOf", and I'm golden!
