Imagemagick Flow
congomonster
Imagemagick Flow
Post by congomonster »
need some help. I want to create a flow where Imagemagick converts the Pictures. The commandline command is this:
convert test.jpg +profile icm -profile sRGB.icc -intent Relative -black-point-compensation -profile ISOcoated_v2_300_eci.icc -density 300x300 test_cmyk.tif
In this case switch should pick up the files and put them into the output folder. I now i can use the execute command tool. But i don't know what to write in. :(
congomonster
Imagemagick Flow
Ok i came one step further. The conversion is ready.
That is what i wrote to the execute command:
Command: C:Program Files (x86)ImageMagick-6.8.6-Q16convert.exe
Arguments: +profile icm -profile "C:Program Files (x86)ImageMagick-6.8.6-Q16sRGB.icc" -intent Relative -black-point-compensation -profile "C:Program Files (x86)ImageMagick-6.8.6-Q16ISOcoated_v2_300_eci.icc" -density 300x300 "%1" "tif:%3/[Job.NameProper].tif"
Important is here that the arguments from Imagemagick comes first!
Output: Result in folder
not null
The big Problem is now that switch makes a folder in the output folder with a file called Job.NameProper.tif. I found out that every sign after the / is written into text. I think i must change something in this part: "tif:%3/[Job.NameProper].tif". Ialso tried 2% but that did not work ):
congomonster
Imagemagick Flow
Ok got it to work! Got help from my co-worker :)
This is what we put in the execute command:
Arguments: +profile icm -profile "C:Program Files (x86)ImageMagick-6.8.6-Q16sRGB.icc" -intent Relative -black-point-compensation -profile "C:Program Files (x86)ImageMagick-6.8.6-Q16ISOcoated_v2_300_eci.icc" -density 300x300 "%1" "tif:%2"
Output: File at Path
copy Job: No
Filtyp: Tiff
Error: not null
solved (:
ppasquier
Imagemagick Flow
Post by ppasquier »
Hi CongoMonster
thanks a lot for your topic, it helps me to how configure my flow but I tried using yours for converting Illustrator EPS files in transparent PNG file
If I tried this comand line in terminal, it's good
/opt/ImageMagick/bin/convert -colorspace RGB -background transparent "" "png32:.png"
I tried this (I'm on macintosh) :
command: /opt/ImageMagick/bin/convert
arguments: -colorspace RGB -background transparent "%1" "png32:%2"
output to path
copy input: yes
extension type: PNG (*.png)
ignoring outcode
It works fine but the result is not good
It looks like the EPS file bad pixelized and not transparent background
I've you, or anyone else, got any idea?
PP
