HP Indigo's G7 Conformance Or ???
msierra
Post by msierra » Tue Dec 10, 2019 12:14 am
Most likely this is not the appropriate place for this post. We have 7 HP Indigo Presses, 3 7250's and 4 7800's. Is anyone, that is running HP Indigo Presses, using any type of Color Management?
We were G7 certified a few years back, which lasted only a couple of years. Since taking over 2 years ago I recommended dropping the Certification as we only certified with a single substrate while we run many substrates.
Now we are looking to institute some CM program that allows us to validate through reading color targets.
LasseThid
Re: HP Indigo's G7 Conformance Or ???
Post by LasseThid » Wed Dec 11, 2019 10:07 pm
We have a 7800, a 7900 and a 12000 and we're using GMG Color Server in Switch to add press profiles to the files before sending them to the presses. Each press have their own profile so the job production is a bit less flexible, but the results (as far as I know) are much better than before.
Enfocus Switch 2019 Spring Edition, Enfocus PitStop Server 19, Enfocus PDF Review, HP SmartStream 12 & Kodak Prinergy 8.2 with RBA
msierra
Post by msierra » Thu Dec 12, 2019 12:24 pm
Thank you for the reply. That's interesting, someone else recommended to use Alwan ColorHub. Both of which provide the same solution.
I'm assuming you're using Device Link profiles. If so, is total area coverage correction implemented as well?
Also, you indicated each press has it's own profile, is it safe to assume that the profiles for GMG were derived from the substrate most commonly used?
LasseThid
Post by LasseThid » Thu Dec 12, 2019 4:51 pm
Unfortunately I wasn't involved when we created the profiles for the presses, so I don't know if there's a TAC correction in there as well.
We normalize everything to Fogra 39 with GMG Color Server in the beginning of the flow and then we do a conversion (again using GMG Color Server)
with the profile for the press.
I assume they used the most commonly used stock when they created the profiles.
