extendscript Toolkit and macOS Catalina
babathemacman
Post by babathemacman »
Is it true that extendscript Toolkit is no longer supported in macOS Catalina. How can I ensure that HP SmartStream Designer Imposition can be used? ?
Re: extendscript Toolkit and macOS Catalina
HP Indigo issued a support bulletin (CN-2353) on December 17th 2019 for customers using Switch in combination with HP SmartStream Designer. The bulletin describes that the SmartStream Designer configurators for Switch use the Adobe ExtendScript toolkit. This toolkit is a 32-bit application and is not compatible with MacOS 10.15 (Catalina). Upgrading an existing Mac to MacOS 10.15 will render the integration dysfunctional. Customers are therefore advised NOT to upgrade to MacOS 10.15.
HP is currently evaluating scenarios to resolve this issue as soon as possible. For more questions you’re advised to consult with your local HP service representative.
