applescript doesn't understand the send to single message
patej
Post by patej »
I created a flow using Applescript to do a simple search and replace in an html file with TextWrangler. The search and replace works fine, but the script ends in error with the message:
'"path-to-file.html" doesn't understand the send to single message'. Same error appears with alias and POSIX paths. Below is the script I've used (replace string left out):
on jobarrived( s, j )
tell application "Switch_Service"
set search_document to path of j
set jobPath to POSIX path of search_document
tell me
replaceText(search_string, replacement_text, search_document)
end tell
send to single jobPath -- neither does "send to single search_document" work
end tell
end jobarrived
on replaceText(search_string, replacement_text, this_document)
tell application "TextWrangler"
activate
open this_document opening in new_window
tell window 1
replace search_string using replacement_text options {search mode:literal, starting at top:true}
close saving yes
end tell
end tell
end replaceText
What is wrong with my script? I found only one example of a script in Applescript and there the send to functions were all "send to data"'s.
Any help appreciated,
Patrik
The correct syntax for send to single is:
send to single j path search_document
But you also need to do another thing: search_string and replacement_text get no values! Add two properties to the script so you can fill them in in your script element, either as an inline value or as a single-line text with variables, depending on your needs. You can set all the possible editors you need in Switch Scripter.
To access the values in your script:
set search_string to value of switch property "SearchString" of s
set replacement_text to value of switch property "ReplaceString" of s
of course, inside the Switch part and with the tag name that you have defined as being a property of the script.
patej
Post by patej »
Thanks! I just wanted to spare you from the long strings I have the script to search and replace, which I have inline so I replaced them with "search_string" and "replacement_text". So everything works now, thanks!
--patrik
