XML-path to string
bkromer
XML-path to string
Post by bkromer »
Hey there,
I use "job.getVariableAsString(' ')" to get a XML-Path as string in my script. But i only get undefined. Also when I try to select that node directly it says that this node is not available altough I can select it. See the pics
Bildschirmfoto 2020-08-21 um 10.09.04.png (34.14 KiB) Viewed 48347 times
Bildschirmfoto 2020-08-21 um 10.24.45.png[/attachment ][attachment=0]Bildschirmfoto 2020-08-21 um 10.06.11.png
My script so far:
	var xml = job.getVariableAsString( '[Metadata.Text:Path="/lieferung/",Dataset="Xml",Model="XML"]' );
	job.log(1,"xml: "+xml);
How can I get the XML-Path "lieferung" as a string in my script?
Benjamin
bkromer
Re: XML-path to string
Post by bkromer »
gosh something is weird with the pics in this forum... :-/
Bildschirmfoto 2020-08-21 um 10.06.11.png (69.79 KiB) Viewed 48345 times
Bildschirmfoto 2020-08-21 um 10.24.45.png (218.24 KiB) Viewed 48344 times
Benjamin
sander
Post by sander »
Escape your " with \ like this
var xml = job.getVariableAsString("[Metadata.Text:Path=\"/lieferung/\",Dataset=\"Xml\",Model=\"XML\"]");
bkromer
Post by bkromer »
sander wrote: Fri Aug 21, 2020 10:40 am Escape your " with \ like this
Flow is not starting then. Also I think I dont need to escape the double quotes because I wrapped them into single quotes... i guess.
Color Highlighting is looking good
Bildschirmfoto 2020-08-21 um 10.47.09.png (46.45 KiB) Viewed 48340 times
Benjamin
bkromer wrote: Fri Aug 21, 2020 10:30 am Bildschirmfoto 2020-08-21 um 10.24.45.png
Your screenshot shows that \Lieverung\ has an attribute and a subnode, but no simple string content. I guess that is why the variable doesn't return anything.
Which return do you want to get?
bkromer
Post by bkromer »
Padawan wrote: Fri Aug 21, 2020 11:36 am
You are right. When I go down to some sub-nodes and select a value it's working.
Well these xml files are heavily nested. "Lieferung" is the main node and I thought I could iterate over the sub elements in my script.
Bildschirmfoto 2020-08-21 um 11.41.25.png (67.94 KiB) Viewed 48335 times
Benjamin
Your have multiple eintrag_pflegen nodes but they seem to have attributes that identify them, so you could perhaps build the XPath like this:
//eintrag_anlegen[@nameOfAttribute='value of attribute']
in order to select the one that you need. This can possibly be followed by another node if you have to dig deeper, and if the value of the attribute is not important you can just specify the attribute as well:
//eintrag_anlegen[@prokom_id]/eintragsversion/nutzung
That is for the job.getVariableAsString method, because that one obviously returns just 1 result.
If you have to iterate over the nodes because you have to use if then to select the correct one, then you have to use the Document class.
var xml = new Document(pathToXMLFile);
var eintragNodes = xml.evalToNodes("//eintragsaenderungen/eintrag_anlegen");
for (var i=0; i<eintragNodes.length; i++) {
    job.log( 1, eintragNodes.at(i).getBaseName());
bkromer
Post by bkromer »
freddyp wrote: Fri Aug 21, 2020 1:23 pm If you have to iterate over the nodes because you have to use if then to select the correct one, then you have to use the Document class.
Thats what I need to do. I need to iterate over all nodes as deep as the tree goes, iterating over all "list" nodes (there are multiple of them).
Then I need to get the values. I thinking of writing a JSON from this.
How can I get an attribute list as a String. Is there a function like stringify for JSON or toString()?
Benjamin
bkromer
Post by bkromer »
	var xml = new Document( job.getPath() );
	var eintragPflegenNodes = xml.evalToNodes("//eintragsaenderungen/eintrag_pflegen");
	for (var j=0; j<eintragPflegenNodes.length; j++) {
			job.log( 1,eintragPflegenNodes.at( j ).getBaseName() );
			var attrList= eintragPflegenNodes.at( j ).getAttributes();
			for (var i=0; i<attrList.length; i++){
				job.log(1,""+attrList.at(i).getQualifiedName()+" "+attrList.at(i).getValue() );
That is how I can get all the attributes under //eintragsaenderungen/eintrag_pflegen with their name and value. Now I need to go deeper and get the underlying nodes and their attribute names and values etc. Would you use getChildNodes() to do this or is there a better way of doing this?
Benjamin
You can use getChildNodes(), but you can also use evalToNodes(xpath). Both return a NodeList object. evalToNodes is more flexible because it is not only capable of getting the direct children but also other nodes further down the tree. It all depends on the XPath, and the XPath depends on the structure of the XML and what you are searching for: https://www.enfocus.com/manuals/Develop ... sions.html.
bkromer
Post by bkromer »
I am nearly finished with my script. There is only one last issue I am facing.
When I eval a node like
var eintrag_anlegen = xml.evalToNodes("//lieferung/eintragsaenderungen/eintrag_anlegen");
And there is no "eintrag_anlegen" in this particular xml-file, I made a check like
if ( eintrag_anlegen.length > 0)
But I am getting the error
"Trying to access undefined member 'length'"
Checking for it being undefined seems not to work.
Like
if ( eintrag_anlegen !== undefined )
and
if ( eintrag_anlegen !== 'undefined' )
both are "true" altough its undefined. :|
How can I get around this in legacy scripting?
Benjamin
if you want to check for undefined you have to:
if (typeof myVariable == "undefined") {
    job.log(3, "myVariable is undefined");
bkromer
Post by bkromer »
Well in the for..loop it seems to work now. But I have a similar issue now with an object.
I have this object:
		prokom_id: '',
		liefergrund: '',
		eintragsversion: {
			bundesweit: '',
			stichwort: '',
			tb: '',
			vab: '',
			lieferanten_id: '',
			gueltig_von: '',
			gueltig_bis: '',
			widerspruch: '',
			nutzung: {
				auskunft: '',
				emedien: '',
				pmedien: ''
			einzeleintrag: {
				eintragsdaten: {
					eintragsdaten_id: '',
					kz_neu_geaendert: '',
					redak_key: '',
					teilnehmerart: '',
					gd_gt_zuordnung: '',
					person_liste: {},
					adresse: {
						strasse: '',
						hausnr: '',
						hausnr_zusatz: '',
						postfach: '',
						plz: '',
						postort: '',
						gd_gt_nummer: '',
						gemeinde: '',
						gemeindeteil: '',
						kuerzel: '',
						geodaten: {
							wgs84_x: '',
							wgs84_y: '',
							lcc_tao_x: '',
							lcc_tao_y: '',
							stadtteil: '',
							qualitaet: ''
					kommnr_liste: {},
					zusatzdaten_infos: {
						typ: '',
						typ_text: '',
						id_datenlieferant: '',
						ergaenzungstext1_name: '',
						ergaenzungstext2_name: '',
						suchworte: '',
						branding: '',
						oeffnungszeiten_liste: {},
						produkt_freigabe: {
							nutzung_tb: '',
							nutzung_gs: '',
							nutzung_oetb: ''
						emedien_freigabe: {
							web: '',
							mobil: '',
							cd: '',
							tv: ''
						verlags_ids: {
							tb: '',
							oetb: '',
							gs: ''
						info_liste: {},
						link_liste: {},
						bewertung_liste: {}
In the first part of my script I read in all the lines of the XML and push the information into this blank object. At the end I have an Array of Objects.
Now I go through this Array and gather the informations to make API Calls. Before I do so i wanna check if the specific information is even there.
So in one case
JSON.stringify(  x[ i ]["eintragsversion"]["einzeleintrag"]["eintragsdaten"]["zusatzdaten_infos"]["produkt_freigabe"] );
gives me this object:
{"nutzung_gs":"","nutzung_oetb":"","nutzung_tb":""}
typeof x[ i ]["eintragsversion"]["einzeleintrag"]["eintragsdaten"]["zusatzdaten_infos"]["produkt_freigabe"]
gives me "object"
but when I try to get the length
x[ i ]["eintragsversion"]["einzeleintrag"]["eintragsdaten"]["zusatzdaten_infos"]["produkt_freigabe"].length
I get the same error Trying to access undefined member 'length'
but when I check for undefined like
typeof x[ i ]["eintragsversion"]["einzeleintrag"]["eintragsdaten"]["zusatzdaten_infos"]["produkt_freigabe"] == "undefined"
its false
So how can I make this work?
Benjamin
bkromer wrote: Fri Sep 11, 2020 4:44 pm but when I try to get the length
This seems normal since the "produkt_freigabe" object is an object (not an array) and it doesn't have a length.
bkromer wrote: Fri Sep 11, 2020 4:44 pm So how can I make this work?
At this point I'm not sure what you are trying to achieve?
