Flattening of pdf content
schmitzdp
Post by schmitzdp »
can Pitstop Pro flatten the content of a pdf (images, objects and text) into a 300 DPI image inside it?
Is it possible ?
Thanks.
laurentd
Re: Flattening of pdf content
Post by laurentd »
Yes, it is possible since PitStop 2019.
We call this "Rasterize selection", because flattening refers to transparency flattening.
Here is a movie about it: https://www.youtube.com/watch?v=BJ4_0ffLUGM
Post by abailescollins »
If you just want to convert all the page content to an image you can also try the Action 'Replace page content by bitmap'
Screen Shot 2020-09-29 at 5.56.22 PM.png (90.03 KiB) Viewed 10625 times
schmitzdp
Post by schmitzdp »
Thank you, both solutions work. :)
However, after applying the Pitstop action, the image is slightly blander than the original.
Is this a profile problem in the color management in your opinion ?
Thank you.
It's difficult to see from the screenshot, what's the input/output colorspace?
schmitzdp
Post by schmitzdp »
CMYK for both
ahh ok
Is it always the same type of input/output profile?
At the moment you have ISO Coated v2 as the input and output profile in the color management options.
Using a devicelink profile before converting to an image might also be worth a try to see the result.
