Communication Switch - Photoshop interrupted
Posted: Thu Oct 08, 2020 10:29 am
since the installation of security update 2020-004 on MacOS 10.14.6 (on a VM) we have issues with Photoshop. It seems that the communication between Switch and Photoshop (21.2.2) is interrupted. I've made many tests but to make it short and clear: If you turn on debugging messages you can see that the script runs 53 seconds until "Script was successfully executed" is logged – compared to 2 seconds run-time on my development machine.
If you select "Save as: Save by action" in the Photoshop Configurator Switch even looses the ticket (Logging: "The job with the same prefix '1DQKG' already exists in the flow. A new prefix will be assigned".), so all metadata are lost.
Any similar experiences ... or a solution?
Kind regards
Jörg
Kind regards
Jörg
