Hello everyone,
does anyone have an SSL certificate installed in Switch? Enfocus itself provides little information, what format is needed, the private key as a text file? And what if there is no password on it? How can I test it?
https://www.enfocus.com/manuals/UserGui ... tings.html
Hope you have the solution. Have a Good day!
Install certificate for SSL
Working with: Enfocus Switch, Pitstop Server, Quite Imposing, Kodak Nexpress (max 640mm sheets and 500grs) with most options (HD, Clear, Gold, White, Light-Black and Matt fuser), Polar Mohr D80 (compucut), Multigraf, Heidelberg, GMP, Duplo, Hohner.
Malcolm Mackenzie
Malcolm Mackenzie
Re: Install certificate for SSL
Well, that is the first step. Thanks! CER en PKCS8 file I link in the setting. My CSR (PKCS8 file) doesn't have a password, so I leave it empty. Restarting, and then message's are not working anymore on the new (https) port. Also working with SSL with custom API's keeps failing.
