Switch Fall 2020 Quite Hot imposing - Requested property is not defined: 'controltype'
cwswitch
Post by cwswitch »
Requested property is not defined: 'controldataset'; trying to use default value
Requested property is not defined: 'controltype'; trying to use default value
Dynamic property 'control' has invalid value
I'm seeing these errors from Quite Hot in the Switch logs.
Does anyone know if my jobs will be OK - can I ignore or is there something I must fix?
(I have written to Quite Hot to ask them too and will report back here if I find anything)
cwswitch
Re: Switch Fall 2020 Quite Hot imposing - Requested property is not defined: 'controltype'
Post by cwswitch »
I've found that by adding a new Quite Hot configurator, more options are available than in the past.
If I then link to a control XML, I can run it with no error showing in Switch.
This makes me think that the errors I was seeing are not mission critical. I now just need to re-add all my Quite Hot configurators :cry:
