Using postscript with Pitstop Server
PdFUser5000
Post by PdFUser5000 »
Is it possible to convert postscript files to PDF with pitstop server?
My workflow currently is: postscript file is converted to pdf via distiller > Pitstop Server PDF2image.
Can i skip distiller and send postscript directly to Pitstop?
Re: Using postscript with Pitstop Server
Post by abailescollins »
No that's not possible. PitStop is PDF only.
You'll need to introduce something like Distiller into the workflow if you want to process postscript.
I would actually try to keep Postscript out of the equation if at all possible, but I know that is not always realistic.
