Save as Optimised PDF from Adobe Acrobat Professional configurator
Posted: Thu Apr 22, 2021 1:40 pm
by LasseThid
Does anyone know if it is possible to save a pdf file as an optimised pdf using the Adobe Acrobat Professional configurator?
I can't find any options for it, so I assume you would have to use a script to do it if it's possible, but how would you write the script to save the file as an optimised pdf with a specific setting in that case?
Re: Save as Optimised PDF from Adobe Acrobat Professional configurator
Posted: Thu Apr 22, 2021 4:42 pm
by Malcolm Mackenzie
Hi Lasse
about 98% certain you can't.
You can combine PitStop cleanup and GhostScript.
GhostScript clears all overhead etc.
Malcolm
Posted: Fri Apr 23, 2021 8:44 am
by LasseThid
Thanks for the information.
We will use PitStop server then.
Posted: Mon Apr 26, 2021 9:49 am
by patej
If you have (or can upgrade to) PitStop 2021 released last week, it has a new action list called "Optimize PDF (emulates Acrobat optimized save)" which should get you similar results than in Acrobat:
Posted: Thu Apr 29, 2021 7:48 am
by LasseThid
Thanks for the information patej.
I do have it, just haven't gotten around to install it. Now I really do have a reason to do it...
