Rotate the page to Landscape
Santhosh@82
Post by Santhosh@82 »
Please let me know how to rotate the pages in PDF using action list.
Our PDF contains Landscape Table content in Portrait mode. So, we want to Rotate the Landscape Tables content pages in to Landscape Mode.
Sample screenshot attached in below..
Input
Input
Output
Output
Thanks,
Santhosh.
laurentd
Re: Rotate the page to Landscape
Post by laurentd »
Santhosh@82
It doesn't work to our files. If i run the actions list, whole pages are rotated.
I need to rotate only if the page contains Table. Not for whole document. Refer screenshot for output.
laurentd
Post by laurentd »
You can base your selection on a specific text (ex "Table", if all tables are rotated).
Then select the pages (if objects are selected) and rotate them.
select text.png (31.42 KiB) Viewed 7864 times
If this is not accurate enough, you can base your selection on the vertical lines in the tables.
select object.png (36.75 KiB) Viewed 7864 times
Post by abailescollins »
Probably best to have an 'AND' after the two selections before the rotation.
