Loop XML with namespace is not working
automation
Post by automation »
I have this XML with namespace and I want to get e.g all the numbers in the Number tag. But the loop is not working with the namespace. I need to use a loop like this because I'am doing other stuff as well in the loop.
<xx.yy xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://xx.se/schemas/xx.yy/3.0/integration IntegrationDocumentSchema.xsd" xmlns="http://xx.se/schemas/xx.yy/3.0/integration">
    <Envelope>
        <Client>Cusomer</Client>
    </Envelope>
    <Data>
        <Item>
            <Number>11111</Number>
            <Balance>2</Balance>
        </Item>
        <Item>
            <Number>2222</Number>
            <Balance>4</Balance>
        </Item>
    </Data>
</xx.yy>
I have this code. I have comment out some code when I try to parse the XML with the namespace but it's not working. I don't need to use the namespace I just need to parse/loop the XML.
	var path = s.getSpecialFolderPath("PluginResources");
	var companyXML = File.toNativeSeparators(path + "/myXML.xml");
	var selectedNode;
	var company = new Document(companyXML);
	//var companyns = 	company.createDefaultMap();
	var companyItems = company.evalToNodes("/xx.yy/Data/Item", null);
	//var companyItems = company.evalToNodes("/xx.yy/Data/Item", companyns);
	for (var i = 0; i < companyItems.length; i++) {
		s.log(1, "Loop working");
If I remove the namespace my code works fine. But I will get the XML with namespace.
<xx>
    <Envelope>
    </Envelope>
    <Data>
        <Item>
        </Item>
        <Item>
        </Item>
    </Data>
</xx>
I can I change my code to make it work with the first XML with namespace?
Re: Loop XML with namespace is not working
The commented lines have to go back in. The problem is the fact that you have not taken into account nodes that use the default namespace. Remember these two principles when using XPaths:
  • when an XML uses namespaces the XPaths must use namespaces for ALL nodes
  • the default namespace in an XPath IS NOT EMPTY. The string that is used for the default namespace depends on the environment; for Switch it is dn.
Without having tested it I would say that this line:
should become
	var companyItems = company.evalToNodes("/xx.yy/dn:Data/dn:Item", companyns);
automation
Thanks it worked!
celinedion
Post by celinedion »
I had this problem too, glad to hear the support info here.
