Simplify a path with Pitstop?
Posted: Wed May 12, 2021 11:50 am
by magnussandstrom
Hi, I'm using the 'Add trace path' in Pitstop but I got feedback from our cutting operators (Kongsberg cutting table) that ask me to reduce the number of nodes in the path if possible. Is there a way to simplify the path in Pitstop (I use' Scan resolution to make a smother path') but is there a way to reduce unessecary nodes that could make the cutting process less efficient? (Like the tool 'Path>Simplify' in Illustrator)?
Re: Simplify a path with Pitstop?
Posted: Wed May 12, 2021 1:20 pm
by abailescollins
Not at the moment, but it is something that makes a lot of sense.
Can't promise anything, but it is on my radar.
Posted: Mon May 17, 2021 8:49 am
by magnussandstrom
Thanks for the quick answer Andrew. We will try to use Automation Engine for this for now.
