Stats.NumberOfPages
foxpalace
Stats.NumberOfPages
Post by foxpalace »
how do I get the Switch-Stats-Values in NodeJS?
Greeting
Michael
laurentd
Re: Stats.NumberOfPages
Post by laurentd »
Hi Michael,
Switch 2021 Spring will bring PdfDocument and PdfPage Classes.
getNumberOfPages( ) is what you need.
It will be released on May 27th.
foxpalace
Post by foxpalace »
Hi Laurentd,
today ist May 27th, System requirements is uptodate, but I can't download 2021 spring. I would like to update my Switch-Dev-Version :)
laurentd
Post by laurentd »
Hi Michael,
The mail about Switch 2021 Spring has been sent an hour ago.
https://www.enfocus.com/en/support/rele ... ease-notes
Sunnyland
Post by Sunnyland »
Looking to get the Width and Height of the PDF Document. I have upgraded to Switch Fall 2021 my node script has be written previous to PdfDocument being added to Spring 2021.
What do I need to do to update my script as it is not reconising PdfDocument as a class?
My nodejs version is 14.15.0
laurentd
Post by laurentd »
Here is an example how to use PdfDocument and PdfPage classes on our EnfocusSW GitHub:
https://github.com/EnfocusSW/PdfProperties
Sunnyland
Post by Sunnyland »
Thanks Laurentd,
But from what can figure out my script is using verion 1.0.1 of types-switch-scripting, To update to fall 2021 I think I should be using version 21.1.0. What is the best way to update this without writing the script again?
laurentd
Post by laurentd »
The PdfDocument and PdfPage classes were introduced with Switch 2021 Spring.
This will update the type definition:
npm i @types/switch-scripting@1.1.0
Sunnyland
Post by Sunnyland »
Thanks Laurentd,
Really appreciate the replies.
I received an error '@types/switch-scripting@1.1.0' is not in the npm registry.
I just had to change npm i @types/switch-scripting@1.1.0
to
npm i @types/switch-scripting and it updated fine.
