				Tracing artwork
				Posted: Fri May 28, 2021 7:32 pm
				by Leogirl
				This may be the same question as earlier posted. How do you reduce the number of points when using "Make Trace Path". I can reduce the number of points in Illustrator but would like to stay in Pitstop .
Thank you
Angela
				Re: Tracing artwork
				Posted: Tue Jun 01, 2021 2:12 pm
				by magnussandstrom
				As I understand it by Andrews answer (in my thread) this cannot be done in the current version of pitstop. But if you can try (in  Trace path Action) set a lower number in the 'Scan resolution (PPI)' you can get a smoother result in some cases. You can also experiment with the slider for 'Curve optimization'. Maybe Andrew can add a 'Simplify-path-slider' to the wish list for next Pitstop release?
