Beta testers for Get Messages app
Posted: Thu Jul 29, 2021 5:05 pm
by jan_suhr
I have made an app that can pick up messages from the Switch messages database. You know all the messages you can see when you open up Messages in your browser. I think that this way of catching messages can be very usefull.
The idea here is to select messages from special things in Switch, all the way to one single element or everything in a specified flow. The message content is saved as private data for you to compose a message out of. This message can then be an email, SMS or anything that can give your attention.
Intention here is to be able to oversee special things that are problematic in your Switch installation or something special you need to get attention to on your Switch server.
The app will create a dummy file for each message row that contains the private data, that dummy file can then trigger an email send.
Since the search criteria is limitless I would like to ask for your participation in testing this app.
This is the settings for the outgoing connection that will pick up the message of your selection. This is the default settings
The attachment Snag_300d64dc.png is no longer available
Settings for the Switch connections, if you have several Switch servers you can connect to any other Switch server on your network and get messages from it.
The attachment 2021-06-10_15-14-28.png is no longer available
Flow
Please contact me if you are interested to test this for me.
Re: Beta testers for Get Messages app
Posted: Fri Jul 30, 2021 10:31 am
by mkayyyy
Hi Jan, this app sounds very promising! I'm interested in testing it
Posted: Mon Aug 02, 2021 1:13 pm
by Arthur
Sounds like what I had a plan to implement via Slack, but not so much with regards to messages, but job statuses.
Switch messages would be another step.
If there is an option to test this one, I am all in :)
Posted: Mon Aug 02, 2021 1:14 pm
by jan_suhr
Arthur wrote: Mon Aug 02, 2021 1:13 pm If there is an option to test this one, I am all in :)
I will send you an email when it is available for testing, it will be any day soon.
