Batch processing actions
drcpub
Post by drcpub »
Would anyone be able to tell me how to use an action on many separate files in a folder? Is there a batch process or a way to use an action I made on hundreds of files?
saitok
Re: Batch processing actions
Post by saitok »
I think you should use "Job dismantler" before the action to take the files out from the folder.
laurentd
Post by laurentd »
Or even better, use "Ungroup job".
It will split the files apart in separate jobs, but each one will have private data attached to assemble them later using the "Assemble job" element, with scheme "ungrouped job".
https://www.enfocus.com/manuals/UserGui ... p_job.html
https://www.enfocus.com/manuals/UserGui ... e_job.html
If you have other file types than pdf, you can also exclude them before the PitStop Server element, and still assemble them later.
