RegEx problem compare names
Posted: Thu Jan 13, 2022 5:29 pm
i have another questions. i hope someone can help me out...
I want to check in the destination folder if a file exist. If the file is there, then the actual job should be send too.
But i have a problem with the name part. The actual file has the "1_Somename__925171_Di_6-AM-42.pdf" and the second one has the name:
"1_SomeOtherName__925171_Di_6-AM-43.pdf".
I have the job name and the name from the second file. But when it comes to comparsion the regex is not working.
Or i doing something wrong
First i get the name of the job:
Then i split the name to cut out the "Somename" part.
Then i get the "SomeOtherName" Part from the SwitchScripter. ( I thougt it would be cool if this name get changed in the future)
Then there is my RegEx code:
After that i put together the name for the second file. The one i searching for
And i have the path also in a const.
After that i do:
So i think the last part with the regex is the problem. If i write the filename without the regex and with the filename hardcoded it works perfect.
So i hope this is not too much.
const jobName = await job.getName(true);Code: Select all
const jobNameSplit = jobName.split('_');Code: Select all
const pdfComparsionName = await flowElement.getPropertyStringValue("pdfComparsionName");Code: Select all
const theregex = / [\w-.] /;Code: Select all
const pdfComparsionNameSearch = jobNameSplit[0] + '_' + pdfComparsionName + '__' + jobNameSplit[2] + '__';After that i do:
try {
if (fs.existsSync(pdfComparsionFilePath + pdfComparsionNameSearch + theregex)) {
await job.log(LogLevel.Info, 'The file is here! hooray!');
//await job.sendToSingle();
} else {
await job.log(LogLevel.Info, 'There is no file.');
} catch (err) {
await job.log(LogLevel.Warning, 'Something went wrong');
