DWG To PDF
SimonMK
DWG To PDF
Post by SimonMK »
Hi All,
I am looking for a solution on how to convert DWG files to PDF.
Any thoughts / suggestions on how to achieve this via Switch / Pitstop etc. would be greatly appreciated.
Thanks & regards.
Malcolm Mackenzie
Re: DWG To PDF
Post by Malcolm Mackenzie »
I think you'll need a CLI application run in Execute command.
An example
http://www.verypdf.com/app/autocad-to-p ... index.html
SimonMK
Re: DWG To PDF
Post by SimonMK »
Many thanks Malcolm, much appreciated. That's exactly what I needed.
quartzibexe
Re: DWG To PDF
Post by quartzibexe »
I am also looking for this information. Very lucky to find here. Thanks
SamCoffee
Re: DWG To PDF
Post by SamCoffee »
Malcolm Mackenzie wrote: Thu Mar 24, 2022 9:21 am I think you'll need a CLI application run in Execute command.
An example
Malcolm,thank you very much.This information is exactly what I've been looking for for a long time now.
