Pitstop server is not converting text to outline
mjtenhoonte
Post by mjtenhoonte »
Pitstop server action list "Convert all text to outlines" is not converting text to outline.
If I check the reason why it is not converting the fonts into outline it tells me in Pitstop Pro that it doesn't have the rights( machtiging ) to do so.
Esko Automation Engine has no problem converting these fonts. Is there a way around this?
mkayyyy
Re: Pitstop server is not converting text to outline
Post by mkayyyy »
When editing a hotfolder on the Fonts section there's a checkbox for "Skip font license checks", if you enable that PitStop Server will skip the license checks and allow you to convert fonts to outlines regardless of the licensing:
There's the same option in the PitStop Pro preferences for this as well
mjtenhoonte
Thanks for the swift answer. I am using it in a switch workflow.I will look in to the hot folder option.
mkayyyy
Post by mkayyyy »
In Switch there's two flow element properties on PitStop Server flow elements to control this functionality "Skip font license checks" and a dependant flow element property "I comply with the font license restrictions":
mjtenhoonte
Thank you.
Exactly what I was looking for !!
