How to Add Metadata Number With Decimals
Posted: Tue May 31, 2022 7:27 pm
I am looking to add a metadata variable upon a Switch Submit Point that has decimals. Currently when the option is selected as a number, it only allows for whole numbers. I am looking to use this value as a variable set within a Pitstop Action which would variable change the width and height of an element being adding to a PDF document.
If the metadata element is set to Variable Text, then I can't pull the variable into the numeric field within PitStop, and if I change the variable element to a number, then I can't add decimal places.
--Evan
--Evan
