Hi to all,
I have a problem, I try to move files from a root hierarchy with Submit hierarchy application but seems it doesn't works...I set subfolders level 0 and Process these folders "No folders". There is one application that in a hierarchy network path move only the files from the root and leave subfolders and others files in the original location?
Thanks for the help!
How to move only files from root in a hierarchy network path
Re: How to move only files from root in a hierarchy network path
Yes, there is an app for that: Inject Wildcard.
It has even more possibilities, like filtering based on name, wildcard, regex, time, depth level.
You have to use a trigger with it, FireStarter is a good candidate.
Thank you for the reply,
Have you also an idea what I can put on "Inject jobs name filter" to move all files? I'm not practice with Regular expression...
Thank you again!
Thank you again!
Subfolder search levels: Root level only
Inject: files only
Injected jobs name filter: *
Name should: match filter
Inject: files only
Thank you very much!
