Inject Wildcard moves job to problem jobs, instead of error connection
PdFUser5000
Post by PdFUser5000 »
When my job repository field is wrong, the jobs is moved to problem jobs, instead of the error connection. Is this correct? Sometimes the repository is wrong in the data and I would like to send an email with the error. But since the job is moved to problem jobs, I have to add the send email element there and not in the flow.
example:
Dynamic property 'jobRepository' has invalid value 'T:\2000182 WLD Agency s.?r.l'
Job '_0U9Y3_B4010--DO0008385.xml' was moved from folder 'D:/Switch data root/backing/sampleflow/automanaged/Folder 24 (Copy)' to the problem jobs folder. Reason: see previous log message(s)
laurentd
Re: Inject Wildcard moves job to problem jobs, instead of error connection
Post by laurentd »
Are you using v4 or higher?
The job repository check was added with v4.
I just tested it with v6 on Mac and Win, it works as expected.
PdFUser5000
I am using v6
essexmate
Post by essexmate »
Also getting the same using Windows and v6. Errors are going to the Problem Jobs folder.
popniete
Post by popniete »
Giving this a bump, I have the same problem with v6 on Windows. Job goes to problem jobs instead of warning connection when folder to be injected is not found.
