Check for spot colors
vernonvd
Post by vernonvd »
I want to create a action list to check if any spot colors is used but to exclude a specific spot like 'Die Trace' or 'CutContour'.
jslater
Re: Check for spot colors
Post by jslater »
I think this may be what you want:
Select all spot colors
Select spot color by name in list (Die Trace, CutContour, etc)
NOT
AND
Log Selection
It will exclude the specified spots from the selection.
vernonvd
Post by vernonvd »
Hi Jslater
that is exactly what i came up with, it works but the log only shows in my case as error " Spot Color (2x on Page 1) and does not list the names of the Pantone colors.
Then you can use "Check number of separations (total page check)". The number of separations should be equal to 0, if certain separations are not counted. You will obviously not want to count CMYK, All and tints with 0%, and then there is a field where you can specify the separation names you do not want to count. Check the "Use regular expressions" option and separate the different spot color names with the pipe symbol:
Die Trace|CutContour
