catch (err) -> err.message
foxpalace
Post by foxpalace »
i have this code from documentation:
    try
    dosomething
    catch (err)
        job.fail('PDF error: %1');
        //job.fail('PDF error: %1', [err]); //grmpf err unknown
why do I get this error, when I use the line whit [err]?
michael@macpro seitenmelder % SwitchScriptTool --transpile .
Error: Failed to transpile the code: TypeScript failed with exit code 2
Error: TypeScript standard output: main.ts(36,42): error TS2322: Type 'unknown' is not assignable to type 'string | number | boolean'.
I tried with err.message too
Re: catch (err) -> err.message
It can sometimes happen that TypeScript does not know the type of a variable and then you get this error message. It is seems strange that this should be the case when catching an error, but that is correct because you can throw anything so TypeScript does not know the type of what will be thrown.
There are two possible approaches.
There is an option you can add to the compilerOptions in the tsconfig.json file in your script folder:
"useUnknownInCatchVariables": false
I will discuss internally if we want to add that for future versions of Switch. I am not sure we should.
The one that you can do immediately, and this is a general remark, is to give TypeScript some help and specify the type:
try {
    dosomething
} catch (err) {
    job.fail('PDF error: %1', [(err as Error).message);
Another example is when there are overloads (more than 1 possible return type). flowElement.getPropertyStringValue for example can return string or string[] depending on whether the property is defined as single line or multiline. If you want to do something with the result as a string TypeScript will complain, and if you want to do something with the result as an array TypeScript will also complain. In this case (and in many/most? other cases) you will probably know what type is returned and then you can do this:
let propValue = await flowElement.getPropertyStringValue("propTag") as string;
Casting a variable is of course also a possible approach to enforce a certain type:
let propValue = (await flowElement.getPropertyStringValue("propTag")).toString();
but this will not always be possible.
crestbrr
Post by crestbrr »
Found an interesting, fairly straightforward way to log error messages. For some reason, wrapping error in a template literal automatically coerces the `unknown` error type to a `string` type instead. Haven't run into unexpected error handling with this yet, but hopefully it helps anyone running into this issue in the future.
  try {
    await job.setPrivateData('foo', 'bar')
    await job.sendToSingle()
  } catch (error) {
    await job.log(LogLevel.Error, `${error}`)
Alastair Scheuermann, Software Engineer @ Sun Print Solutions
Connect with me on LinkedIn
`${error}`
is equivalent to
error.toString()
That is indeed a possible approach, but for the sake of completeness: you do not get the same result as with:
(error as Error).message
Coercing an Error object to a string gives you a longer string including some stack information and also the message, but it is a bit lost in that longer string. For developers that is more useful, but for users it is more confusing because the gist of the error is in the message.
