Select object by coordinates so I can modify the height of the box
Posted: Wed Oct 12, 2022 12:06 am
by JJBrs
How do I go about selecting a box on my page so I can modify the overall height? I need to move up the crop by 1/4 in from the bottom to allow for a postage barcode? I have over 10,000 records and the box in question is on my even pages--all the same, bleeding top to bottom. I would like to insert an action to select it and then to modify the height. I have a group of other actions that will run within the same action but this one alone has me stumped. Your assistance is greatly appreciated.
Re: Select object by coordinates so I can modify the height of the box
Posted: Wed Oct 12, 2022 7:50 am
by JimmyHartington
You have to look at the Select by region action. And remember it can bet set to select overlapping or complete inside region.
And it can be combined with other selects like color etc. using the AND operator.
Posted: Wed Oct 12, 2022 3:06 pm
by JJBrs
Jimmy,
Thank you for that reply. After selecting inside region AND fill color to select the box I want, what is the name of the command to use to physically change the dimensions or height of the box?
Posted: Wed Oct 12, 2022 4:02 pm
by JJBrs
I found the scale selection function and that is doing the trick. Thank you for your help!
