Replace low res QR code
Posted: Fri Nov 18, 2022 4:12 pm
Hi all
I'm trying to create a small Switch flow with PitStop Server where I can put in a PDF with a low resolution QR code and replace that with one created by PitStop Server. I've managed to read the QR code and am able to pass it to Switch through the report. I then save the contents of the QR code into a private data field and then create the new QR code in a separate action list. The problem: The content is multi-line (a VCARD) and apparently neither PitStop nor Switch's private data support multi-line text in that scenario. Is there another way I could approach this?
