Check if FONT exists in PDF or not
rhd_ole
Post by rhd_ole »
I'm trying to find a solution that I can have a check done if a font exists in a PDF or not. We are having some issues where barcodes are not generated due to improper weights, till the update happens the only way to check this outside a manual visual inspection is to see if the font is in the file or not from what Ive found. I'd like to do the check and fail if the font isn't there.
I tried to use PitStop to try and report it or not, I'm not seeing a way to do that.
Any other suggestions?
JimmyHartington
Re: Check if FONT exists in PDF or not
Post by JimmyHartington »
I would make it by "Select font by name" and then a "Log selection" with warning or error in regards to what your needs are.
"Select font by name", "Check font is embedded" is a better alternative.
rhd_ole
Post by rhd_ole »
Thanks everyone.
freddyp wrote: Tue Jan 10, 2023 8:47 am "Select font by name", "Check font is embedded" is a better alternative.
This worked great. Then for some reason I realized I could use [Stats.Font] and then used [Stats.Font] contains <FontName> and it worked. Think this will be cleaner workflow not using PS.
Thanks again!! Always keeping me thinking.
Jemis
Post by Jemis »
Open the PDF file on Adobe Acrobat Reader > Click File > Select Properties > Click Font. To identify fonts and paragraphs in PDF files, you must use Adobe Acrobat Pro (free): geometry dash scratch Right-click on the paragraph on the PDF file > Click Edit Text & Images > Highlight the text and paragraph you want to check. and see the Format section.
rhd_ole
Post by rhd_ole »
diamond wrote: Fri Nov 17, 2023 3:32 am One way to check if a font exists in a PDF is to use Adobe Acrobat Pro.
1. Open the PDF file in Adobe Acrobat Pro.
2. Click on "Edit PDF" in the right-hand pane.
3. Select the "Edit" option from the toolbar.
4. Click on the text that uses the font you want to check.
5. Right-click on the text and select "Properties" from the context menu.
6. In the "Text Properties" dialog box, look for the "Font" section.
If the font is embedded in the PDF, it will say "Embedded" next to the font name. If it is not embedded, it will say "Not Embedded".
We were looking for an automated check vs manually checking the fonts, it was a unneeded stopping point.
For this specific case I used built in switch variables [Stats.Font] contains <FontName>. and routed depending if it existed or not.
We did something similar to report non-embedded font to the customer as well. This was done the via PitStop Sever,
1. Pitstop Action to look for non-embedded fonts.
2. Recored the font error.
3. Exported the error log
4. Picked up Log as XML
5. Set the error line XML Path as PrivateData and used it in a variable within the email template that sends out errors to clients.
6. Enjoy not having to manually do it.
WillyDickens
Post by WillyDickens »
rhd_ole wrote: Thu Nov 30, 2023 12:40 pm
We did something similar to report non-embedded font to the customer as well. This was done the via PitStop Severtunnel rush,
Thx. I also had the same problem and your solution helped me to fix my error.
rhd_ole wrote: Thu Nov 30, 2023 12:40 pm We did something similar to report non-embedded font to the customer as well. This was done the via PitStop Sever,
I want to say something about 3 and 4: if you use a "Data with Log" output connection from the PitStop Server app the XML report is immediately attached as a dataset: no need to export and pick up. That makes the flow a bit shorter and more efficient.
