TypeScript Cannot Find Names
DtM
Post by DtM »
I've just tried making my first TypeScript file since having Switch Spring 2022.
I used the follow SwitchScriptTool command to make the folder:
"C:\Program Files\Enfocus\Enfocus Switch\SwitchScriptTool\SwitchScriptTool.exe" --create "SendOrdersToPrinter" .\
After opening main.ts in Visual Studio Code, I'm immeditaley presented with these three errors, which apply to the JobArrive function declaration:
	"resource": "/d:/ControlFiles/Switch Assets/Scripts/Client Specific/Shell/SendOrdersToPrinter/main.ts",
	"owner": "typescript",
	"code": "2304",
	"severity": 8,
	"message": "Cannot find name 'Switch'.",
	"source": "ts",
	"startLineNumber": 3,
	"startColumn": 30,
	"endLineNumber": 3,
	"endColumn": 36
	"code": "2304",
	"severity": 8,
	"message": "Cannot find name 'FlowElement'.",
	"source": "ts",
	"startColumn": 51,
	"endLineNumber": 3,
	"endColumn": 62
	"code": "2304",
	"severity": 8,
	"message": "Cannot find name 'Job'.",
	"source": "ts",
	"startColumn": 69,
	"endLineNumber": 3,
	"endColumn": 72
I'd assumed that as I used SwitchScriptTool, all of the type definitions should already be setup for me, can someone please assist?
Re: TypeScript Cannot Find Names
It is clear that the Switch typings are missing. I have seen this happen before but it is not clear to me what the exact cause is. But if you type:
npm i
it will be OK (it reinstalls all missing packages defined in the package.json file).
If not, check the package.json file for the link to the Switch typings and try using that link with npm i.
