I have read several post involving postscript conversion. Current work flow has photoshop converting the EPS file to a flattened image. Please recommend a PDF conversion in workflow without flattening the image.
Thank you
EPS to PDF
- JimmyHartington
Re: EPS to PDF
Do you have Distiller og Illustrator installed?
Both can convert/save eps as PDF.
Re: EPS to PDF
No we do not and I am seeing some documentation that Distiller is not permitted to run on servers.
Angela Smith
Re: EPS to PDF
No we do not and I am seeing some documentation that Distiller is not permitted to run on servers.JimmyHartington wrote: ↑Tue Feb 21, 2023 8:18 am Do you have Distiller og Illustrator installed?
Angela Smith
- JimmyHartington
Re: EPS to PDF
Then I have no ideas how to do this best.
UPDATE: You could perhaps use Ghostscript. See this post: https://stackoverflow.com/questions/785 ... eps-to-pdf
