Switch Calculation for ><
freshmic1
Post by freshmic1 »
I'm trying to write a Switch calculation that uses greater than/less than. I can't find any documentation on specific calculation expressions.
Is there a guide on the language that is used? I don't even know what that language is called.
Or does anyone have a sample calc that uses greater than/less than?
Re: Switch Calculation for ><
If you set a "condition with variable" where the value is a sort of number (integer or real), then the condition should contain number related value such as "Greater than", "Less than", or "Equal to".
The value to be compared can then use a switch calculation but the type of data must be a "number"
Does that help?
