Switch internal job database ("ghost" jobs)
Posted: Tue Mar 14, 2023 4:52 pm
Hello community!
While doing some testing on a flow, I made the mistake of deleting jobs within a checkpoint, and deleting some flows while they were processing jobs.
Lesson learned! But now I have some "ghost" jobs that I can't remove from the Active Jobs list on the dashboard, even though all the backing folders and everything related to them are gone.
I found something that looked helpful here...
viewtopic.php?t=2129
I got as far as attempting connection to the database at localhost:55091, but the connection (now in the new version of Switch?) requires authentication, and I don't know the internal database structure so I can't tell 3T the path to the authentication database.
Any help with this would be really appreciated!
But this program has been acquired by a new company (now Studio 3T) and the directions don't match the new version.TheCaptain wrote: ↑Thu Mar 22, 2018 1:00 pm In order to get rid of the old 'ghost' jobs you will need to stop Switch and remove...
• Install RoboMongo (https://robomongo.org/download)
• Start Switch
• Start RoboMongo
• On first start the "MongoDB connections" pane will be open
• Click the Create button
• Keep type on "Direct connection"
• Give the connection an easy name like "Switch MongoDB"
• Keep the address to localhost
• Set the port number to 55091
• Click the Connect button
You can now see the contents of the MongoDB database used by Switch
• Open SwitchCore/ Collections/ Jobs
• You have several keys here, each of them resembles one job which MongoDB knows about
• Search for the "ghost" files in this list
• When you are really sure that the Switch job ticket for the job you see is already cleaned up, then it is safe to remove the job from MongoDB
• You can do that by right clicking the object and choosing "Delete Document..."
The next time you refresh the joblist in the webportal the job won't be shown anymore
