Merged pdf-files
ramses
Merged pdf-files
Post by ramses »
I have a group of pdf-files, all with the same name, but with 2 different prefixes:
a_1_XXX.pdf, a_2_XXX.pdf, a_3_XXX.pdf, ...
b_1_XXX.pdf, b_2_XXX.pdf, b_3_XXX.pdf, ...
In both directions the number of files is variable, but i can't know in advance how much.
For the letter, after z it continues to aa, ab, ...
The letter-prefix and the number-prefix are also PrivateData.
I would need different merged pdf's, one for each letter in the right order of the numbers. So one pdf for a_1 + a_2 + a_3 + ..., one pdf for b...
I tried with Assemble job, but can't seem to get it right.
I hope someone can help me with this one?
Thanks in advance,
Ramses
magnussandstrom
Re: Merged pdf-files
Post by magnussandstrom »
Would this work for you?
Since you don't know how many files you are getting I set a time limit in Assemble job to 10 minutes (you can change it as you like). The flow will group jobs with the same prefix (before the first underscore) and sort alphabetically when merging the PDF.
I suggest to set the Assembled job folder name to [Job.NameProper:Before="_"]_merged or similar.
ramses
Post by ramses »
Yes, this does the trick.
Thanks!
