Remove rows from CSV
vernonvd
Post by vernonvd »
Hi
I am looking for a way to remove the fist 3 rows from an incoming csv file in Switch, any ideas will be apricated :shock:
magnussandstrom
Re: Remove rows from CSV
Post by magnussandstrom »
I would try to use Easy Data Transform with Run Command app to do this.
https://forum.easydatatransform.com/t/f ... bers/204/2
vernonvd
Post by vernonvd »
Hi magnussandstrom,
Great! I did read about Easy Data Transform a while back, will look into this.
Thanks.
magnussandstrom
Please post here if you get stuck on the Run Command "Command" for Easy Data Transform, It was a bit tricky to get it to work initially.
magnussandstrom
I made a Switch flow and an 'Easy data transform preset' that removes the first 5 rows. You can edit it and change file format to fit your specific case.
Download (avaliable for 2 weeks): https://bit.ly/3Lp8eQ8
Example of Run Command command: "C:\Program Files\EasyDataTransform_1_44_0\EasyDataTransform_1_44_0.exe" "\\URL-to-preset\preset.transform" -file "Input=%%InputFilePath%%" -file "output=%%OutputPath%%\[Job.NameProper].xlsx" -cli
