Building an archive structure by file names
pfischer
Post by pfischer »
Hello all,
I need some help with a switch task.
I want to archive PSD-files in a structure based on the file names.
The file name always consists of an 8-digit number.
I.e. from 00000001.psd to 99999999.psd
The archive folders should always contain a specified range of numbers.
E.G.:
00000001-00001999
00002000-00003999
00004000-00005999
Thus, a maximum of 2000 files per folder will be archived.
If now an image with the name "00012345.psd" exists, the archive folder should be called
be named 00012000-00013999.
So far I only manage to sort the files via endless manual filter specifications. Unfortunately, this is an extremely time-consuming and error-prone method.
Does anyone have an idea if this can be solved more elegantly with a little math and switch logic?
Thanks for your support.
Best regards,
Peter
Phoenix Contact GmbH & Co. KG
www.phoenixcontact.com
tdeschampsBluewest
Re: Building an archive structure by file names
Post by tdeschampsBluewest »
Hi Peter,
Just put the following variables in a "Set hiearchy path" and here you are :
[Job.NameProper:Search="^[0]+"][Switch.Calculation:Expression="round(([job.NameProper]/2000)-0.5)*2000"]-[Job.NameProper:Search="^[0]+"][Switch.Calculation:Expression="round(([job.NameProper]/2000)+0.5)*2000-1"]
Get the leading 0 :
Number of leading 0 is already contained in your jobName, just look for it with a regex :
Calulate upper and lower value :
we need to "floor" or "ceil" the value divided by the range wanted then remultiply by itself
Exemple with lower limit
floor(12345/2000)*2000
floor(6.1725)*2000
6*2000=12000
How to do it in with only "round" function :
Since we only have "round" function within switch, we need to force this behaviour by adding +0.5 and -0.5.
Lower :
round(12345/2000 - 0.5)*2000
round(6.1725-0.5)*2000
round(5.1725)*2000
6*2000=12000
Upper :
round(12345/2000)*2000
round(6.172560.5)*2000
round(6.6725)*2000
7*2000=14000
Switch version :
Do not forget to remove 1 for the upper limit and here we go!
pfischer
Post by pfischer »
Hi tdeschampsBluewest,
thank you for this clever solution and especially for the explanation!
Unfortunately, there is still an error (see screenshot).
Because of the better readability I used only the "start folders", i.e. the first part of your formula. So the folders should be as follows:
00000000
00002000
00004000
00006000
Strangely, for file names between 00000010 and 00000099 (6 leading zeros) or 00000100 and 00000999 (5 leading zeros) a separate folder with 6 or 7 zeros is created. Actually, these files should also be sorted into the folder with 8 zeros.
For files with 7 leading zeros (e.g. 00000001.psd) this also works correctly.
Do you have an explanation for this?
Thank you very much for your great and helpful support!
Kind regards,
Peter
tdeschampsBluewest
Effectively, for file under the range index number of digits (4) and above 9, some problem can happen.
For example with 00000999 : the regex part will give 00000 the calculation part will give 0, and that's not the wanted number of digits.
Another solution, if you have the last version of switch + the new rename element version, is to use the "Add leading 0" action.
See example here
Capture d'écran 2023-07-06 114224.png (45.24 KiB) Viewed 16255 times
