				Remember specific position in XML
				Posted: Tue Aug 01, 2023 9:30 am
				by FlorianDSK
Is there any way in Switch to write out a position in an XML when a specific value is found?
As an example:
XML structure
   Jobs
      Job
         item: Indoor sticker
         Format: A6
      Job
         Article: Sticker Outdoor
         Format: A7
      Job
         Article: Special sticker
         Format: free format
And in this case it should search for free format and recognise that it is 3 in the job and then remember this value 3.
Many thanks in advance
Florian
				Re: Remember specific position in XML
				Posted: Tue Aug 01, 2023 2:37 pm
				You can use an XSL transformation to capture the position of 'free format' in another XML that you can then attach as a dataset. The XSL would look something like this (I cannot be 100% sure because you did not share the real XML code):
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
    <xsl:template match="/">
        <freeformat>
            <xsl:for-each select="//Job/Format">
                <xsl:if test="string() = 'free format'">
                    <xsl:element name="position">
                        <xsl:value-of select="position()"/>
                    </xsl:element>
                </xsl:if>
            </xsl:for-each>
        </freeformat>
    </xsl:template>
</xsl:stylesheet>
				Posted: Tue Aug 01, 2023 3:48 pm
				by FlorianDSK
				Hello Freddy,
Please find attached the XML.
However, we do not have a script extension for Switch.
Is there another possibility?
<jobs>
	<job>
		<order>
			<item>Indoor Sticker</item>
			<format>210x210</format>
			<freeFormat>round 21</freeFormat>
		</order>
	</job>
	<job>
		<order>
			<item>Outdoor Sticker</item>
			<format>95x95</format>
			<freeFormat>round 9,5</freeFormat>
		</order>
	</job>
	<job>
		<order>
			<item>Special Sticker</item>
			<format>190x290</format>
			<freeFormat>free format</freeFormat>
		</order>
	</job>
	<job>
		<order>
			<format>105x148</format>
			<freeFormat>a6</freeFormat>
		</order>
	</job>
	<job>
		<order>
		</order>
	</job>
	<job>
		<order>
			<format>52x74</format>
			<freeFormat>a8</freeFormat>
		</order>
	</job>
</jobs>
				Posted: Tue Aug 01, 2023 5:38 pm
				You do not need the scripting module, there is a default element "XSLT transform" with which you can apply the XSL. Save the XSL code I posted in a file and use that file on the "XSLT stylesheet" property.
Based on the true XML you will have to change the line:
to:
<xsl:for-each select="//freeFormat">
				Posted: Wed Aug 02, 2023 12:08 pm
				by FlorianDSK
				This works perfectly. Many thanks for that.
The background is that we need the individual position numbers for a switch loop. These are written out thanks to your XSLT.
We then give these to the asset as Dataset=Position, in addition to the normal XML.
Now Switch should search for the term freeFormat in the normal XML, but only in the XML position, which we then want to pass to it through the other dataset=position.
Is there a way to retrieve metadata in metadata?
[Metadata.Text:Dataset="Xml",Model="XML",Path="/jobs/job[Metadata.Text:Dataset="Position",Model="XML",Path="/freeformat/position[1]"]/order/productDescription",Search="freeFormat"]
				Posted: Wed Aug 02, 2023 1:41 pm
				There is an app for that:
https://www.enfocus.com/en/appstore/pro ... able-xpath
But you are overthinking it. It is easier to simply copy the tag. Instead of
</xsl:element>
you use
				Posted: Tue Aug 08, 2023 11:06 am
				by FlorianDSK
				Hello Freddy,
The requirements have changed again and we had to structure the workflow completely differently.
But your app suggestion was great, I appreciate that and I will keep the app in mind for future worklfows.
kindly
Florian
				Posted: Wed Sep 27, 2023 9:15 am
				by FlorianDSK
				Hello frailwhen,
Is there for instance a new way to deposit metadata into existing metadata as described here:
Feel free to share with us so that others may find an easier solution for their project
