Is there a way to collect multiple XML's (10+), take all the information out of them and write it into one XML?
Many greetings
Florian
[Solved] Combine several XML
FlorianDSK
Re: Combine several XML
The app Make XML can do it.
FlorianDSK
Hello Jan,
Thank you for your quick reply.
But is there no other option than another payment app?
kindly
Florian
kindly
Florian
- magnussandstrom
If you install Saxon (open source software) and use the Saxonica configurator in Switch you should be able to merge XML files.
Install: https://github.com/Saxonica/Saxon-Archi ... n-HE/9/9.9
About the merge instruction: https://www.saxonica.com/html/documenta ... merge.html
Strangely I can't seem to download the 9.9 HE version from Github anymore.. maybe someone can help out here?
FlorianDSK
Hello Magnus,
Thank you for your answer. Appreciate that
But I have now solved this using a batch file
Thanks anyway
Kindly
Florian
Thanks anyway
Kindly
Florian
joaodaffonsojr
Re: [Solved] Combine several XML
Hi !
I have two XML like 32800_ARQOS.xml and 32800_ODTPLIMP.xml that i need to merge.
I tried with SAXON in the cmd line, I did a XSLT and works.
But how can I use the variables of Switch like [Job.Path] and [Job.NameProper] to make SAxon configurator merge them ?
Any tips are very welcome !
