Switch integrated with Prinergy
arothenberger
Post by arothenberger »
Good morning,
There is a YouTube video showing the integration with Switch and Prinergy. Does anyone know the person that posted this? I would like to view the flow in more detail, in regards to generating a Prinergy XML file.
Best Regards,
Adam
Post by dkelly »
Andrea Mahoney, Automated Workflow Developer @ Tribay Enterprise in Ontario, Canada
Evan
Post by Evan »
Hi Arothenberger,
You need to have RBA (Rules-Based automation) installed with your Prinergy. Then you use an event or manual trigger with the action "Write Text to File" to make an XML. Your XML can contain all variable of prinergy needed like job name or a folder to pickup.
In Switch you can associate a folder made by Prinergy with the XML you just have create with "XML Pickup'. The XML will be store in a dataset that you can use later to drive back your files.
If you don't have RBA with your Prinergy you can create a folder named as your job and use that name to put back your files in the right directory or job hotfolder using "Archive hierarchy" configurator in Switch.
giuliana.dusi
Re: Switch integrated with Prinergy
Post by giuliana.dusi »
Hi to all.
it's possible to have the link of this video to see how this flow works?
Giuliana
pietdepauw
Site Admin
Post by pietdepauw »
It's indeed on our YouTube channel, however it is no longer listed.
This URL will take you there: https://www.youtube.com/watch?v=26ARqv_IB4I
