Error in script expression when using setPrivateData
AA5MC
Post by AA5MC »
I have a script expression and I'm trying to set : job.setPrivateData('Destination', 'MyDestination');
However, the script is erroring saying that job.setPrivateData is not define?
Is it possible to set job.setPrivateData in a script expression?
if so anyone have a example?
Re: Error in script expression when using setPrivateData
Script expressions only have read access to the switch api.
If you want to set private data using a script expressions, then you can use the data mapper app. There you set the tag in the app and calculate the value using a script expression.
AA5MC
Post by AA5MC »
thank you!
