Tilla Griffin missing: Rotate 0 or 180 degrees!
Egon
Post by Egon »
Dear Switch users!
is there a possibility that I can set the Rotation of the nesting in Tillia Switch to 0 or 180 degrees? A very common nesting option but apparently missing in the Tillia Griffin Plugin for Switch! :shock:
We make a lot of custom boxes that can be rotated 0 or 180 degrees because of the flutes, but this option is simply missing! Is a variable set possible?
Best regrads,
Egon
Enfocus Pitstop Pro | Enfocus Pitstop Server | Enfocus Switch | ArtiosCad | Workflow Designer
Linkedin | GraphicWorld bv.
laurentd
Re: Tilla Griffin missing: Rotate 0 or 180 degrees!
Post by laurentd »
Hi Egon,
Please try this:
  • Use advanced mode
  • Define flutes direction on your substrate
  • Define flutes direction on your artwork
Griffin app Flutes 1.png (47.63 KiB) Viewed 21338 times
Griffin app Flutes 2.png (30.98 KiB) Viewed 21338 times
Egon
Post by Egon »
Hi Laurent,
Serious? Totally missed those Artwork proportions! It can be that simple!!!
Thanks Laurent! :D
