Logging of variable
JimmyHartington
Logging of variable
Post by JimmyHartington »
Hi
I have made a small script, which takes an URL and encodes it with "encodeURI". See code below.
It fails if I try to log the encoded URL.
If I do no logging it works and sets the private data correctly.
I get this error:
Invalid placeholders in log message
    at Object._0x4028cb [as _log] (C:\Program Files\Enfocus\Enfocus Switch\ScriptExecutor\nodemodules\node_modules\switch-scripting\index.js:727:23)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async _0x48bf25.log (C:\Program Files\Enfocus\Enfocus Switch\ScriptExecutor\nodemodules\node_modules\switch-scripting\index.js:2735:17)
    at async jobArrived (D:\Switch-Scripts\EncodeURL\main.js:1:982)
    at async _0x45c618 (C:\Program Files\Enfocus\Enfocus Switch\ScriptExecutor\nodemodules\node_modules\switch-scripting\index.js:1278:28)
    at async D:\Switch-Scripts\EncodeURL\main.js:1:3352
In this test, the encoded URL is set to "https://www.skabertrang.dk/en%20lille%20test".
Should the log not be able to show this?
    let URLtoEncode: string = await flowElement.getPropertyStringValue("URLtoEncode") as string;
    let PDKey: string = await flowElement.getPropertyStringValue("PDKey") as string;
// Encode complete URL
let encodedURL: string = await encodeURI(URLtoEncode) as string;
await job.log(LogLevel.Info, "URL to encode: \"" + URLtoEncode + "\"");
await job.log(LogLevel.Info, "Encoded URL: \"" + encodedURL + "\"");
await job.setPrivateData(PDKey, encodedURL);
await job.sendToData(Connection.Level.Success);
foxpalace
Re: Logging of variable
Post by foxpalace »
Hi
await job.log(LogLevel.Info, "Url to encode: " + URLtoEncode);
patej
Post by patej »
This is due to Switch reading the %2 from your string and interpreting that the log message includes a placeholder (%1, %2 etc) to replace like you could use it await jog.log(LogLevel.Info, 'Message about %1',[jobName]); <–– here the %1 is replaced with jobName variable.
So you can get around this by using a variable:
await job.log(LogLevel.Info,'Encoded URL: "%1"',[URLtoEncode]);
or by replacing the %20 with a space in the message:
await job.log(LogLevel.Info,`Encoded URL: "${URLtoEncode.replace(/%20/g,' ')}"`);
The reason that the logging of an encoded URL does not work hangs together with the way in which the logging works. If you look at the documentation you will see that the log method takes 3 parameters: a log level, a log string and an array of strings for replacement in the log string:
let replacements = ["abc", "def"];
await job.log(LogLevel.Info, "This is value 1: %1. And this is value 2: %2.", replacements);
will log
This is value 1: abc. And this is value 2: def.
Many would write this as:
await job.log(LogLevel.Info, "This is value 1: " + replacements[0] + ". And this is value 2: " + replacements[1]+ ".";
and that wil log exactly the same.
Now consider string translations. The second method is problematic because the part of the log string that requires translation is split over two different strings. With the first method that is not the case: you translate 1 string with the %n in the right place and that is it. That is the background on why this is the way it is.
An unfortunate side effect is that the % sign is also used in URL encoding. That was not a consideration when the above method was chosen many years ago. Today another replacement character would have been chosen. So, if your encoded URL contains %20 the Switch logging mechanism wants to replace the %2 by the second element in the array of strings of the third parameters, but in your case there is no third parameter and it fails.
As a workaround you can do the following:
let replacements = ["%1", "%2", "%3", "%4", "%5", "%6", "%7", "%8", "%9"];
await job.log(LogLevel.Info, encodedURL, replacements);
JimmyHartington
freddyp wrote: Fri Sep 08, 2023 1:32 pm As a workaround you can do the following:
I tried to add this code to the script.
But it gives the same error.
Since the logging works this way, I think I will just not log this info.
patej
Post by patej »
JimmyHartington wrote: Fri Sep 08, 2023 1:48 pm
Did you try my suggestions above? I tested only in a script expression, but both work there:
JimmyHartington
patej wrote: Fri Sep 08, 2023 1:06 pm So you can get around this by using a variable:
Thanks patej.
This method works.
await job.log(LogLevel.Info,'Encoded URL: "%1"',[encodedURL]);
So now the finished code is like this:
    await job.log(LogLevel.Info, 'URL to encode: "%1"', [URLtoEncode]);
    await job.log(LogLevel.Info, 'Encoded URL: "%1"', [encodedURL]);
    await job.log(LogLevel.Info, 'Private Data Key "%1" set to "%2"', [PDKey, encodedURL]);
