Image compression
Posted: Thu Sep 21, 2023 10:58 pm
by Gearstudios
Recently had a job that the concern was file size. Got set of actions to help with the file size then once deployed the file size was different that what was expected based on initial testing. Question is does color management on the pitstop server change the images compression after an image has been rasterized or replaced with a bit map image using actions?
Re: Image compression
Posted: Sat Sep 23, 2023 11:38 pm
by loicaigon
Hi there,
Not really sure about your issue. If you want to send me samples before/after and actions you are using, I can have a look.
loica (a) enfocus (dot) copm
Posted: Sun Sep 24, 2023 11:35 am
by Padawan
It can indeed change the image compression. You can change the behavior by adding the "Override default image recompression" action before the action which is changing the images.
