Calculations with Switch private data
JimmyHartington
Post by JimmyHartington »
Hi
In a flow I needed to calculate how many times a step and repeat imposition could be repeated on 965 mm.
I could not get my math to work with Switch calculations, so I decided to write a script to calculate and return a new private data key with the number I needed.
But it took me way to long because I think I messed up declaring my variables as numbers/floats.
The code below works, but is probably not the best code.
What is the best way to read a private data key and have the script intepret it as a number (which can contain decimals)?
    let ImposeRoll: string = await job.getPrivateData("ImposeRoll");
    let BleedRoll: string = await job.getPrivateData("BleedRoll");
    let Width: string = await job.getPrivateData("Width");
    let ImposeRollPrintOnCutterFloor: number = 0
    let ImposeRollPrintOnCutter: number = 0
    let MarksRollPrint: number = 0
    ImposeRollPrintOnCutterFloor = await Math.floor((965 / (Number(ImposeRoll) * (Number(BleedRoll) + Number(Width)))));
    ImposeRollPrintOnCutter = await ImposeRollPrintOnCutterFloor * Number(ImposeRoll);
    MarksRollPrint = await Number(ImposeRollPrintOnCutter) - 1;
    await job.setPrivateData("ImposeRollPrintOnCutter", ImposeRollPrintOnCutter);
    await job.setPrivateData("MarksRollPrint", MarksRollPrint);
    await job.log(LogLevel.Info, "ImposeRoll: " + ImposeRoll);
    await job.log(LogLevel.Info, "BleedRoll: " + BleedRoll);
    await job.log(LogLevel.Info, "Width: " + Width);
    await job.log(LogLevel.Info, "ImposeRollPrintOnCutterFloor: " + ImposeRollPrintOnCutterFloor);
    await job.log(LogLevel.Info, "ImposeRollPrintOnCutter: " + ImposeRollPrintOnCutter);
    await job.log(LogLevel.Info, "MarksRollPrint: " + MarksRollPrint);
    await job.sendToSingle();
laurentd
Re: Calculations with Switch private data
Post by laurentd »
Hi Jimmy,
let Width: number = parseFloat( await job.getPrivateData("Width") );
And in case Width is a property:
let Width: number = parseFloat(await flowElement.getPropertyStringValue("Width") as string);
JimmyHartington
I have tried to clean up the code:
    let ImposeRoll: number = parseFloat(await job.getPrivateData("ImposeRoll"));
    let BleedRoll: number = parseFloat(await job.getPrivateData("BleedRoll"));
    let Width: number = parseFloat(await job.getPrivateData("Width"));
    let ImposeRollPrintOnCutterFloor = await Math.floor((965 / ImposeRoll * BleedRoll + Width));
    let ImposeRollPrintOnCutter = await ImposeRollPrintOnCutterFloor * ImposeRoll;
    let MarksRollPrint = await ImposeRollPrintOnCutter - 1;
But does not get the correct values as I expect
laurentd
Post by laurentd »
priority of mathematical operators!
try this: let ImposeRollPrintOnCutterFloor = await Math.floor( 965 / ( ImposeRoll * ( BleedRoll + Width )));
JimmyHartington
Perfect. Thank you very much.
I had the correct parentheses in an earlier version, but probably messed it up trying to wrap it in Number() as in the code I posted first.
JimmyHartington
For completeness here is my finished script
    // Use parseFloat() set the variable as a number, so math works
    // Remember to use correct order of operations when doing math
