Archive hierarchy issue
LasseThid
Post by LasseThid »
I have a flow that archives zip files based on their file names.
Basically I have an input folder where the zip-files are placed when jobs are exported from our prepress workflow system.
I then have a Set hierarchy path that use that file name to create the path segments before I use Archive hierarchy to tell the flow which server and folder to archive the files in (Safe move is set to Yes).
Enfocus Switch is running on Windows and the file server is also running on Windows.
The problem I have is that all files archived by this flow have the attributes Hidden and Archive set, which mean that I can't see the files from my Mac until I go to a PC and change these attributes. As far as I can see there are no settings in the Archive hierarchy where I can change these attributes.
Does anyone know why these attributes are set and how to disable them?
Thanks in advance.
Lasse Thid
Re: Archive hierarchy issue
Turn off "Safe move"
LasseThid
Post by LasseThid »
Thanks Jan.
It sounds contradictory, but I'll give it a shot. :lol:
That worked perfectly!!!
